OK. End then? Where how to install. Is there any proper documentation on Cura and plugins?
Put the folder of the plugin (PostProcessingPlugin) in the plugin folder of cura. A new menu item should apear under extentions
On a Mac that means opening the Cura.app, OK?
I found two Plugin folders. One in resource, one in resources -> Cura.
Tried both, no luck.
I have no idea how to do it on mac.
Jeex inside the cura package keep digging, there's a pluging folder. On the new cura it's really a mess of folders, but keep digging.
Nice try. Found a third Plugins folder in the new Cura:
Contents -> Resources -> Uranium -> Plugins
So Cura has three plugin folders. And the fun of it: still no go.
Maybe add a fourth plugin folder?
C'mon guys. Make some documentation on Cura. And i do not mean technical documentation, but useable documentation. This really sucks.
1
Old cura had much less folders. Specially less sub sub sub folders. Also having the stuff inside the package it's a really bad idea (all versions).
Dim3nsioneer 557
A little bit tidying up and documenting would be nice indeed. As another example, at least on Windows, Cura.log is not where the dialog box says to look for...
But maybe with the next version all these issues are solved...
- 2 weeks later...
And still no answer on how to activate the Pause plugin. So back to the old Cura.
We gave you an answer? You need to put the plugin with the other plugins in the plugin folder. If it's not recognised, post the log file. With the little information you give, I can't help you any further.
Dim3nsioneer 557
@Jeex: Have you tried the latest beta? There, the postprocessing plugin with the PauseAtHeight script is already included.
You can find the beta at http://software.ultimaker.com/Cura_closed_beta/15.10/
nallath 1,118
https://github.com/nallath/PostProcessingPlugin
There ya go
