well i'm pretty sure that i choose the correct printer.
One thing i found out is that the printer homes on Z-12.55.
I've tried adding G92 Z0 in the gcode after a G28 but the problem remains.
I watched your video and it looked like it homed perfectly - right when the nozzle hits the bed. Right? not 12mm from the bed.
Can you please post the first 50 lines of your gcode file? In UMO settings it's very easy to put some bad gcodes in the "gcode start" settings that will do what you describe.
well it homes perfectly but when you look at the info screen (@ 0:25 seconds) you will see that the Z axis homes at -12.55. So even when the printhead hits the endstops which should make it think it's at 0, the Z axis homes to -12.55.
Posting the first 50 lines of code won't really help i think, but here goes nothing.
Edited by GuestM190 S70.000000M109 S210.000000
;Sliced at: Tue 25-08-2015 23:21:37
;Basic settings: Layer height: 0.1 Walls: 0.8 Fill: 20
;Print time: 3 hours 40 minutes
;Filament used: 1.901m 15.0g
;Filament cost: None
;M190 S70 ;Uncomment to add your own bed temperature line
;M109 S210 ;Uncomment to add your own temperature line
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F9000 ;move the platform down 15mm
G1 F200 E3 ;extrude 3mm of feed stock
G1 F9000
;Put printing message on LCD screen
M117 Printing...
;Layer count: 25
;LAYER:0
M107
G0 F9000 X17.800 Y6.300 Z0.300
;TYPE:SKIRT
G1 F1200 X46.632 Y6.300 E0.54235
G1 X46.653 Y7.609 E0.56697
G1 X166.297 Y7.609 E2.81754
G1 X166.297 Y6.300 E2.84217
G1 X195.200 Y6.300 E3.38585
G1 X195.200 Y35.195 E3.92938
G1 X193.892 Y35.195 E3.95398
G1 X193.892 Y154.804 E6.20389
G1 X195.200 Y154.804 E6.22850
G1 X195.200 Y183.700 E6.77205
G1 X166.297 Y183.700 E7.31573
G1 X166.297 Y182.391 E7.34035
G1 X46.723 Y182.391 E9.58961
G1 X46.734 Y183.700 E9.61423
G1 X17.800 Y183.700 E10.15849
G1 X17.800 Y154.804 E10.70204
G1 X19.108 Y154.804 E10.72665
G1 X19.108 Y35.195 E12.97656
G1 X17.800 Y35.195 E13.00116
G1 X17.800 Y6.300 E13.54470
G1 F2400 E9.04470
G0 F9000 X21.600 Y10.100
Is this the case with every print, or just some?
Has it always done this, or only recently?
In what version of Cura did you slice it?
Thank you!
What the hell!!!! I've never seen that! I missed that in the video as it goes by in under a second. Yes I see that now. Very strange! This is a Marlin issue, not a Cura issue.
Somehow Marlin has this 12.55mm offset. I have no idea where that comes from - when you home with G28 Z0 it should show 0mm, not -12.55mm.
Did you build marlin yourself? Where did you get this copy? If you built it, search for "12.5" in Configuration.h (and configuration_adv.h). Also doing a "factory reset" might fix things - that number *might* be stored somewhere not in the marlin hex file but somewhere else which I believe gets cleared with factory reset command. Not sure.
it's a recently build self sourced UMO+. Some parts are original like the ulticontroller, the mainboard, stepper motors and the heated bed. The rest is gathered from different places.
So it's a new problem on a new printer, so you can say a new problem that has been happening recently
I flashed a custom firmware that clears the whole eeprom etc. then reflashed the printer with cura 15.04 (Thesame firmware i had on it before)
For some reason the printer has been functioning right untill now. Some under extrusion problems but nothing strange i can't fix myself.
So thank you everyone for the input! Let's hope the problem doesnt return
I missed something. Did flashing the eeprom fix the problem?
gr5 2,097
My UMO does the exact same thing when I create the gcode with cura and accidentally choose um2 as the machine instead of umo. Could that be it?
