Can I use Ultimaker 2 in Thailand?
Posted · Can I use Ultimaker 2 in Thailand?
Hi @Yutkaset,
Thank you for your post.
Could you specify your question?
Why wouldn't you be able to use it?
Do you mean if you can import it, or actually use it?
If you specify your question, it would be easier to answer it.
Thank you!
Hi Sandervg,
Thank you for your answer. Thailand has the voltage and the power plug is different from Europe. I just worry when I bought this, I will not be able to use it
Thank you.
    Thank you for your patience. I double checked and you
    can definitely use the Ultimaker 2 inThailand.
    I understand you have different power sockets available, if you have access to the top one in your post make sure to select the european power chord, or use a converter.
    But finding a fitting powerchord shouldn't be a problem I think :)
