Netfabb start at height 0.22 instead of 0.15
digixx
Posted · Netfabb start at height 0.22 instead of 0.15
I made a material definition with a layer size of 0.15mm. In Styles -> 'Region Definitions' i selected for 'Outer' the layer type 'Every half layer'
With this the print starts at a height of 0.08mm which is correct for half 0.15mm.
If I choose for 'Outer' layer type 'Every layer' the print starts at a height of 0.22mm which is a bit to high to get stable contact to the surface.
Why does the software choose 0.22mm instead of 0.15mm?
Hardware/Software:
Ultimaker with UltiController and SD-Card
netfabb Version 4.9.3 Ultimaker Edition.
Regards
Uwe
