Pretty sure they shouldn't be tapped. You'll "tap" them when you run the screw through. At least that's how it was when I assembled mine 3 years ago. I doubt that has changed since.
Thanks for your reply! This is the line in the instructions that is throwing me off:
"All limit switches are pre-tapped, you can fasten them directly with M3 bolts, no nuts required here!"
If the bolts are self tapping, perfect. But, I didn't want to force them when it says the switches are pre-tapped.
Thanks,
Alex
IRobertI 516
