Hey Sander, totally right - I will add that. Thank you for the contribution!
D is just a connection point, i should call it P in the future for "pressure".
So, if you reach D, you continue at "Have you checked the distance between the nozzle and the printbed?"
At the moment I try to understand how to distinguish between an overheated driver and losing steps. I think that's not totally corret in the chart at the moment.
SandervG 1,520
Hi Thank you for creating this chart!
I will run it down our tech department too, to see what they think of it.
Is it based on the Ultimaker 2 or Ultimaker Original?
Because the Original usually doesn't 'click' (the feeder) but the Ultimaker 2 doesn't have an electronics fan.
For the Ultimaker 2, I don't believe the reason of the clicking is the driver becoming to hot.
The current on the motor is on the low end of the spectrum, so instead of grinding (when the friction increases) it starts skipping. Cause: somewhere down the line friction increased.
Can be because the speed/temp is out of balance, or friction increased in the bowden, or the ptfe/teflon deformed, or your nozzle has dirt in it.
What does 'D' mean?
Maybe we could expand this with pictures, like.. what are clear markings on the knurled wheel etc?
Another plausible cause when the filament is difficult to move through the bowden tube, is that it got flattened and became to wide. So another step should be; try another piece of new filament.
Potentially you could also add a technique to test if your PT100 works accurately, to test if 100ºC is actually 100ºC. This can be done for example pushing a piece of filament against the heaterblock at 80ºC, it should start to deform due to the heat.
Does anyone have a better way of testing the PT100 without fancy equipment?
Edited by GuestLink to post
