Need help annotating g code
skeats
Posted · Need help annotating g code
Hi guys
I'm new around here so I'm not sure if this has been posted before but for an assessment we are doing in school we have to annotate the first ten lines of g code for our printed products. I've looked around but there doesn't seem to be anything on the topic.
here are the the lines of code:
;Layer count: 3039
;LAYER:0
M107
G0 F9000 X98.997 Y100.966 Z0.300
;TYPE:SKIRT
G1 F1200 X106.740 Y95.343 E1.14832
G1 X108.771 Y93.763 E1.45710
G1 X118.371 Y93.764 E2.60910
G1 X120.940 Y93.657 E2.91765
G1 X128.777 Y99.351 E4.08011
thanks for your time
    Posted (edited) · Need help annotating g code
    I think this is what you want:
    http://reprap.org/wiki/G-code
    And to get you started:
    ;Layer count: 3039  //I think this is self explanatory
    ;LAYER:0 //I think this is self explanatory
    M107 //Print cooling fan off
    G0 F9000 X98.997 Y100.966 Z0.300 //Set Feedrate to 9000 (F) and do a rapid linear move (G0) to the specified XYZ coordinates
    ;TYPE:SKIRT //Start printing skirt
    G1 F1200 X106.740 Y95.343 E1.14832 //Feedrate to 1200 and Linear move (G1) to the specified XY coordinate, while extruding 1.14832 mm. filament
    etc.
    Btw. are you sure those are the first lines of code?
    I would expect something like this to come before it (Kind of a bad example as this is a 1 layer print with almost no time or filament used... but it was something I had lying on my desktop and I guess you get the idea):
    M190 S60.000000 ;Set bed target temp. to 60 degrees and wait
    M109 S220.000000 ;Set hotend target temp to 220 degrees and wait
    ;Sliced at: Tue 18-08-2015 21:19:56
    ;Basic settings: Layer height: 0.2 Walls: 0.8 Fill: 0
    ;Print time: 0 minutes
    ;Filament used: 0.02m 0.0g
    ;Filament cost: None
    ;M190 S60 ;Uncomment to add your own bed temperature line
    ;M109 S220 ;Uncomment to add your own temperature line
    G21        ;metric values
    G90        ;absolute positioning
    M82        ;set extruder to absolute mode
    M107       ;start with the fan off
    G28 X0 Y0  ;move X/Y to min endstops
    G28 Z0     ;move Z to min endstops
    G1 Z15.0 F12000 ;move the platform down 15mm
    G92 E0                  ;zero the extruded length
    G1 F200 E3              ;extrude 3mm of feed stock
    G92 E0                  ;zero the extruded length again
    G1 F12000
    ;Put printing message on LCD screen
    M117 Printing...
    That's perfect thanks heaps guys.
    the other lines of code before that was:
    ;FLAVOR:UltiGCode
    ;TIME:41733
    ;MATERIAL:21332
    ;MATERIAL2:0
    ;Layer count: 3039
    ;LAYER:0
    Those are just comments. They do nothing other than inform humans about things.
    @tommyph1208 - don't you realize you just got some kid to get to skip over doing his homework? Don't make it *too* easy or they won't know how to do the same thing next time.
    Haha, you are right about that but hey... Its his loss, not mine.
    I never believed in forcing people to learn stuff they don't actually have a genuine interest in... That especially goes for something like this.
    That fact that he found his way to this forum, gives me hope though ;)
