I think I want one like this
jaros
Posted · I think I want one like this
Hi all,
In past few weeks I can say, I discovered 3D printing, and I think it will be awesome for my little projects. I did some research about 3D printers and looks like Ultimaker is what I want.
I was putting stuff in ultimaker's shop basket, and I've seen that there is yummy looking field called "Discount Codes".
So the most important question now is for all coupons hunters, where those codes are popping up... facebook, tweeter, forum ???
Regards
Jarek
Nashville,TN
USA
    I think it's a default feature of the webshop software that Ultimaker uses. And maybe the support section gives out coupon codes for replacement parts. But there are no "coupon actions" that I know off.
    Hi all,
    Regards
    Jarek
    Nashville,TN
    USA
    It's used when they decide after to charge you less, for example freight. Then they give you a coupon to the value of what you've overpaid to use on your next order.
