I printed a 50mm sphere that came out fairly good. I think I just used support from Cura or KISSlicer. I know I didn't create any support from the Cad program. I would try it without brim or raft. Good luck and post a picture of your end result if you like.
cloakfiend 994
Lol, this was one of the first things i tried. The answer is the low points of the sphere nearest the bottom will always look lame. Period. If you want things perfect you need to understand the limitations, then it is smooth sailing. You need to problem solve a lot and decide how to slice things into multiple parts in order to print them best. The higher res you go the worse overhangs are as well. Good to keep that in mind but yo can use different programs to get specific supports for your needs. If your new to this its a constant learning game, and even a year on im finding better and quicker ways to do stuff and better glues for the glass and better tecniques at cleaning and so forth. Be ready to learn thats all. Then you can print cool stuff, and almost anything.
Edited by GuestI check the Z height of the sphere in Cura and "Cut-off Bottom" in Advanced settings to sink half the sphere into the bed, then rotate 180 degrees to print the other half (unless the sphere is identical on both hemispheres). Sometimes I cut off an extra 0.1mm or so to account for the glue.
I also strategically cut off the bottom of parts that don't have a planar bottom surface or that were modeled with a slight rotation. Off the top of my head, Raptor and Baryonyx claws were the last objects I split and glued. I much prefer that method to supports or raft.
DidierKlein 729
Yep i agree best bet is to cut in half and glue after.
The overhang is to steep for the first part of the sphere it will be ugly no matter what you try
thanks for the replies. It referred to printing a BB8 so changing orientation doesn't help
Printing BB8 as well
ultiarjan 1,222
With questions like this it's always practical to add a picture...
Perhaps you can split it and print 2 half's? or print it in another orientation?
