Normally cura will detect an SD card is inserted and save directly to it. Is your computer detecting the SD card? Or am i misunderstanding your question?
tinkergnome 918
Assuming you are using Cura 15.04, you should take a look at "File -> Preferences".
Remove the base path (leave it empty) and it should act like in older versions of Cura.
(i don't know if there is an equivalent setting for the "new Cura")
Well I put my 3D Printer files on a network share drive (Seagate GoFlex) and I have everything sorted out nicely, which makes it several directories deep on the SD card.
Most of the time, the pop up from below shows blank upon saving the file so I am growing tired of hunting for it
@nallath I haven't checked the beta yet, but can this be a check box type of thing? Save to root by default instead of imitating the system file path? It isn't very natural to clear out that field
Uh, yeah, we could add that. If you make a github issue it's less likely that we forget it
Ok, how do you make a github issue?
Well the GitHub joining process was a little awkward.....might i suggest, if you want more feedback, you sticky an item on how to report issues and that link.
DidierKlein 729
What version of Cura? And what OS?
