Posted · Cal cube size problems
So when i print the 20mm cal cube its comes out at about 19.6 ish not 20. I am using Cura and I do calibrate the filament extruder as part of the setup and its very precise.
I am curious where that error comes from? Any ideas?
I thought it has to do with the steppers or their drivers.
    I would assume that this would not be resolved by a heated bed would it? Especially on taller parts.
    I am building another 3D printer out of profiles and currently deciding to salvage ultimaker parts or not. The arduino board is easy enough but the extruder I'm hating and would like a MakerBot style extruder.
