Nice! I'd love to know how much weight it can lift. A UMO or UM2 can lift about 5kg or about 10 pounds:
https://ultimaker.com/de/community/view/5222-pulling-force-of-um-extruder?page=1
I could rig something up to find out, I can guarantee its significantly more than the stock UMO or UM2 feeders. The stepper motor is larger and has a 5:1 planetary gearbox so it should have roughly 5x the pulling force.
Edited by GuestI'm certainly interested in this.
Although, any particular reason for using a different stepper motor than the stock motor?
Higher torque and better resolution. The gears have a larger diameter than the stock knurled feeder, which negatively affects resolution (lowers steps per mm) so to compensate and add more torque (something the original drive motor is a bit lacking) I'm using a geared motor..... and I had one laying around
Having a more powerful extruder means you can print at lower temperatures and faster speeds.
Edited by GuestThanks, that really helps explain things. I'm definitely interested in this though (I've been following your progress for a while now) and would love to give it a try. I really want to be able to effectively print XT CF-20.
Anyhow no matter with how much force you can push something it won't change the fact that the filament needs x time to reach the print temperature. There's physically a limit of how much filament can reach the temp per sec. The only way to reach much more speed/sec its to have a larger hotzone. Ofc more force will help but also there's a limit of preassure and heat/time.
There is also "lash" to consider, i.e. imprecision introduced by having a couple of levels of gearing involved.
Edited by GuestAnyhow no matter with how much force you can push something it won't change the fact that the filament needs x time to reach the print temperature. There's physically a limit of how much filament can reach the temp per sec. The only way to reach much more speed/sec its to have a larger hotzone. Ofc more force will help but also there's a limit of preassure and heat/time.
This is true but the stock extruder really lacks the torque required to extrude even at normal speeds. With our stock Ultimakers we need to run ColorFabb XT at 240C to print at 40mm/s without underextrusion. With the gear extruder we can at 60-70mm/s.
The backlash in the geared extruder seems to have little if any effect. I did have to increase my retraction a bit but I believe that is just due to the increased pressure on the filament.
I am running a series of test prints to effectively measure the impact of the gear extruder vs the stock one. I will post it when I have it done.
Edited by GuestDid a quick speed test. The tower on the left uses the gear extruder the one on the right uses the stock extruder. The gear extruder looks good up to 120mm/s where the stock extruder starts showing signs of underextrusion around 70mm/s. Both printers were printing clear XT at 240C.
I'd really like to see the test - it's very easy if you have a scale and a bucket and something heavy to put in the bucket and a bungee. Oh and I guess you need pronterface so you can move the Z slowy and watch the scale carefully.
The feeder may be 5X but the grip strength is probably only 2X (two sides instead of one). I agree with your comment about retraction by the way.
I've heard that splined extruders (versus diamond knurled pattern) have the problem that they can get PLA dust in them that doesn't fall out as easily as the knurled pattern.
Pronterface is a fantastic tool if you don't have it - it lets you measure all the sensors like end stops easily and change acceleration parameters, max speed parameters and so much more but most importantly you can move Z slowly by any amount. Free download here:
http://koti.kapsi.fi/~kliment/printrun/
Thanks for the link, I'll see what I can do about getting that test performed.
From some of the testing I have already performed the geared stepper motor will skip steps before the gears loose grip on the filament, so from that I believe I can safely say the motor will be the limiting factor not the grip. I haven't had any slipping/grinding so far so there isn't any dust in the gearbox so far.
Very interesting! Looks awesome!
Anyone know how to change the maximum retraction speed? I've had to increase the retraction distance to 10-12mm and I want to up the retraction speed to something like 55-60mm/s. I'm guessing its something I would have to change in the firmware but I'm not sure how to change it? Any help would be greatly appreciated.
You can use pronterface to see the firmware current max retractions acceleration with the M501 command. Then you can issue M203 amd M201 commands to change it.
I tried asking about the default setting bing too low here
But never got any replies, but that post shows what you should see.
Don't forget to save your firmware settings after you change them you have to use a M500, otherwise reboot the printer and your adjustments will go away, sometimes this is what you want.
Edited by GuestUpdated version of the gear extruder:
I have also updated my fan shroud design to accomodate the stock Ultimaker nozzles, improve airflow and include a template for the Kapton tape cutouts.
https://www.youmagine.com/designs/um2-olsson-block-fan-mount
Edited by GuestPrinted a few doorstops with the gear extruder and Olsson block. The 0.8mm nozzle and 0.4mm thick layers makes a sizable dent in the print times. The print time went from over 4 hours to just over 1 hour. The gear extruder could extrude faster but the heater isn't strong enough to keep the nozzle hot.
.4mm nozzle,
ColorFabb XT
0.12mm layers
70mm/s
Print time: 4h 34m
.8mm nozzle,
ColorFabb XT
0.4mm layers
50mm/s
Print time: 1h 4m
Edited by Guest@mendells I have also been following your progress for a while. Great work!
Count me in!! Name the price, and tell me when it will arrive
Whats your ideal launch date?
Count me in as another person interested in your design. Excellent work you have done thus far!
There is a lot of work to do before production so I don't know for sure when that may be.
A question for those who may be interested. Would you rather?
A: Receive all hardware and print the gearbox, motor mount and motor adapter yourself ($100-150)?
B: Receive all hardware and 3D printed gearbox, motor mount and motor adapter ($130-180)
C: Receive all hardware and machined aluminum gearbox, motor mount and motor adapter ($200-250)
Prices are rough estimates, just trying to get an idea what people would want.
Edited by GuestOption A.
Since the original feeder would be un-harmed in this setup, I could always print myself replacement parts if something was to happen with the previously printed parts.
mendells 52
Unfortunately the geared stepper motor is too long to mount internally. You could potentially mount it internally if you removed the sheet metal shield that covers the stepper motors but I wouldn't recommend that. I am not 100% happy with the mounting location or method yet so it may still change in the future. I would like to mount it closer to the top of the machine and offset far enough so it doesn't stick out the side.
As for the program changes, the only thing that has to be changed is "E-Steps per 1mm filament" in the machine setting. The default is 0 (which I believe the default is something like 86) and the new value is 443.46.
