Drawings for Ultimaker 2 go?
Zapro
Posted · Drawings for Ultimaker 2 go?
Hi. A happy UMO-owner here :)
I'd like to build my own, customised Ultimaker 2 go-clone with a lot of inspiration from it. As far as i can see, all mechanical parts on it is identical to the ones on the 'Ultimaker 2' and 'Ultimaker 2 Extended' but i need the measurements on the case.
Will these drawings be made available at some point? I have looked on github and i can only find the drawings/source files for the 'Ultimaker 2'
// Per.
    • 2 weeks later...
    @SandervG nice and punctual :) thanks!
    I put a reply on the story page, but it seems to have been removed (no problem, if it was my site I would not even allow replies on those front pages at all anyhow) but I asked if you can also publish the assembly step file of the "GO" (as you also did with the UM2). All the individual parts are there but arranging them properly in CAD again is a bit of a pain and for you guy's it's probably a 2 minute job...
    Is it removed? hmm, let me look into that. That shouldn't happen.
    I saw your question this afternoon and forwarded the question. I'm sure it won't be a problem.
