Dim3nsioneer 557
Is it possible you post the generated gcode somewhere (don't post it here as text, please)? If you cannot post the whole gcode, maybe the first few layers?
The layer thickness of the base plate is .05".
Layer height: 0.1
link to the g code file
https://www.dropbox.com/s/ppq2dk2g41nkbtq/20x20%20booth.gcode?dl=0
Thanks for the help!!
Can't find anything especially unusual. z layer heights are in the correct order. However, Cura tries to make some infill for the thin walls which starts in the second half of the base layers. This is not very nice.
You will also see the combing lines.
peggyb 169
Maybe try Cura 15.04 to see if you have the same problem there?
And can you see something in first layer in the Layer view?
What is the thickness of the base plate? and your first layer thickness?
