Thank you for your reply.
It seems that something on the the shield is broken.
- playing with Ulticontroller cables gives no effect (two lines of screen are covered with rectangles),
- pushing the knob doesn't make buzz sound,
- on/off switch deosn't work,
- the only thing that works is bottom fan and top diode,
- two green leds (led6, led7) on the board are shining, but led 6 is stronger,
- there are sparks when I plug in power adapter - looks like short circuit to me,
- when I connect arduino with shield on top to my computer it recognizes Arduino MEGA.
Because it's brand new I will contact support/my local dealer and try to get it serviced.
But just for the curiosity - depending on those symptoms - do you have an idea what could have cause it? I will get multimeter tommorow - I can test some parameters if you tell me where to check.
gr5 2,334
Play with the cables going to the ulticontroller - it's easy to get them backwards but I don't think anything will break if you hook them up wrong. also if you push on the knob it should make a buzz/beep sound.
If the board is truly damaged you should probably contact support - start here:
support.ultimaker.com
