cloakfiend 990
Im mid print now, so ill put a few drops of sewing oil on and hope it works, i just need it to be ok for a few more days! im praying.....
just had a look and noticed one of the pulleys with the teeth on it (if that is a pulley), is shaking a few millimetres as its moving? none of the others are moving, and its in the direction of the slip. so ill need to tighten somthing after over a years worth of printing non stop i guess. i hope it can last a few more days..... its probably as im printing alot on one bed, and its moving tons all over and quite sharply.
IRobertI 502
Are you sure it's skipping teeth and it's not just a classic case of pulleys not being attached tight enough?
http://support.3dverkstan.se/article/23-a-visual-ultimaker-troubleshooting-guide#shifted
