Stepper motor jammed.... makes buzzing noise but shaft doesnt rotate
Posted · Stepper motor jammed.... makes buzzing noise but shaft doesnt rotate
The x axis stepper motor of my UM2 is jammed. It only makes buzzing noise but the shaft of the motor doesnt rotate.
the other motors are working fine.
Is there a way to trouble shoot this problem??
There cannot be a mechanical obstruction inside the motor because it is completely sealed.
i tried to loosen the pully attached to the shaft but the hex bolt is extremely tight and the key keeps slipping.
