I have seen that before. I selected millimeters and exported. I know Sketchup isn't the most reliable .stl generator out there, so I imported the .stl to 123d Design and re-checked dimensions. The weird thing is, the same .stl sliced three times gave three different answers. The model is supposed to be 8-3/8" length. One is 8-1/16", one is 8-1/8", and the final is 8-1/4". I just sliced the model in Cura 15.04 and started it, then paused after the first couple layers and measured it and it seems to be scaled appropriately.
I've got previous examples of this same model printed from the same .stl in the same program at the right scale, so I am not sure what exactly is going on. I thought maybe I'd thrown something off in the printer, but I printed a few Benchys and measured them against the dimensions online and everything seems correct there. I'll do some more checking with the current Cura and if I don't find anything, I think I'll re-install.
gr5 2,070
Sometimes sketchup saves things in inches and STL's have no units and Cura expects everything in mm so I simply multiply by 25.4 and everything scales perfectly and accurately.
The "errors" between sketchup and Cura should be an EXACT number like 10 or 25.4 (10 if sketchup exports in cm).
