UM2 power questions : do I need to ground the board ?
Posted (edited) · UM2 power questions : do I need to ground the board ?
For "the machine i'll someday build" I have a few high quality industrial power blocks. As I don't have the right connector I think I'll just wire one up directly and remove the board connector.
Question;
Is it ok to only use the +-  or do I also need to ground the board? and if so should I ground the board by connecting the mains ground to the inner metal part of the connector (green circle in the picture) ?GroundPower.thumb.jpg.e08742f03bd4c12c4f81a1838deb53dc.jpg
    Posted · UM2 power questions : do I need to ground the board ?
    ok, just got a brainwave :) a bit late... I know.... easy to measure..... on the original UM2 powerblock the outerring of the plug is indeed directly connected to the mains ground..
    All I know is that if you don't ground it and rest your forehead against the frame you get a nice little tingle going on :p I live in an old apartment where the only grounded outlets are in the kitchen so I don't have much choice in the matter.
        • 10 replies
