Thanks for your long explaination. It is really helpful. You just mentioned that you can have it switch off after a set time. So how to do this? Does the ultimaker support this function or need I modify the firmware? I just do not want the machine power on all the time until I turn off it. Thanks a lot!
Thanks,
Vincent
No It doesn't have this function.
When the print is finished it will cool down but stayed powered on.
If I am to leave it and the print will finish when i'm away then I normally turn the LED's off. this can be done when the machine is printing under TUNE, and set LED's to 0%. You can also set it so the LED's turn off automatically when the printer is finished or to do different things under expert settings on the printer.
or you could get a power point timer and have it switch off after a set time. I always add an extra 30mins on the timer just encase.
Labern 772
