Cura Steam Engine not accepting .ini profile files
loskiorama
Posted · Cura Steam Engine not accepting .ini profile files
Hey,
I'm trying to slice an STL with a profile I created with cura's GUI
The problem I have is that when I try this i get the following error:
Default config 'default.cfg' not used?
Config(C:\Program Files (x86)\Cura_15.04\profile.ini): Line zd: No key value pair found
Failed to read config 'C:\Program Files (x86)\Cura_15.04\MCF.ini'
It works fine on the GUI,
Why it's not working on the command line? What could be wrong??
Thanks
    Don't know if I could really help, but it might help others if you provide the ini/cfg files you are having issues with.
    Have you manually tweaked these at some point OR did it always blow up?
    Have you tried to do a clean re-install (backup config files first, just incase)?
    Sure, here it is:
    [profile]
    layer_height = 0.2
    wall_thickness = 0.8
    retraction_enable = True
    solid_layer_thickness = 0.6
    fill_density = 10
    nozzle_size = 0.4
    print_speed = 70
    print_temperature = 210
    print_temperature2 = 0
    print_temperature3 = 0
    print_temperature4 = 0
    print_bed_temperature = 50
    support = None
    platform_adhesion = None
    support_dual_extrusion = Both
    wipe_tower = False
    wipe_tower_volume = 15
    ooze_shield = False
    filament_diameter = 2.85
    filament_diameter2 = 0
    filament_diameter3 = 0
    filament_diameter4 = 0
    filament_flow = 100.0
    retraction_speed = 70.0
    retraction_amount = 4.0
    retraction_dual_amount = 16.5
    retraction_min_travel = 1.5
    retraction_combing = True
    retraction_minimal_extrusion = 0.02
    retraction_hop = 0.0
    bottom_thickness = 0.2
    layer0_width_factor = 100
    object_sink = 0.0
    overlap_dual = 0.15
    travel_speed = 70.0
    bottom_layer_speed = 20
    infill_speed = 0.0
    inset0_speed = 0.0
    insetx_speed = 0.0
    cool_min_layer_time = 5
    fan_enabled = True
    skirt_line_count = 1
    skirt_gap = 3.0
    skirt_minimal_length = 150.0
    fan_full_height = 5.0
    fan_speed = 100
    fan_speed_max = 100
    cool_min_feedrate = 10
    cool_head_lift = False
    solid_top = True
    solid_bottom = True
    fill_overlap = 15
    support_type = Grid
    support_angle = 60
    support_fill_rate = 15
    support_xy_distance = 0.7
    support_z_distance = 0.15
    spiralize = False
    simple_mode = False
    brim_line_count = 20
    raft_margin = 5.0
    raft_line_spacing = 3.0
    raft_base_thickness = 0.3
    raft_base_linewidth = 1.0
    raft_interface_thickness = 0.27
    raft_interface_linewidth = 0.4
    raft_airgap = 0.22
    raft_surface_layers = 2
    fix_horrible_union_all_type_a = True
    fix_horrible_union_all_type_b = False
    fix_horrible_use_open_bits = False
    fix_horrible_extensive_stitching = False
    plugin_config =
    object_center_x = -1
    object_center_y = -1
    [alterations]
    start.gcode = G28 X
    G28 Y
    G28 Z
    G29; Detailed Z-Probe
    G1 Z3
    G1 X100 Y200 F3000
    G1 Z0
    G1 Z5 F5000 ; lift nozzle
    end.gcode = ;End GCode
    M104 S0 ;extruder heater off
    M140 S0 ;heated bed heater off (if you have it)
    G91 ;relative positioning
    G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
    G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
    G28 X0 Y0 ;move X/Y to min endstops, so the head is out of the way
    M84 ;steppers off
    G90 ;absolute positioning
    ;{profile_string}
    start2.gcode = ;Sliced at: {day} {date} {time}
    ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density}
    ;Print time: {print_time}
    ;Filament used: {filament_amount}m {filament_weight}g
    ;Filament cost: {filament_cost}
    ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line
    ;M104 S{print_temperature} ;Uncomment to add your own temperature line
    ;M109 T1 S{print_temperature2} ;Uncomment to add your own temperature line
    ;M109 T0 S{print_temperature} ;Uncomment to add your own temperature line
    G21 ;metric values
    M107 ;start with the fan off
    G28 Z0 ;move Z to min endstops
    G1 Z15.0 F{travel_speed} ;move the platform down 15mm
    T1 ;Switch to the 2nd extruder
    G1 F200 E10 ;extrude 10mm of feed stock
    G1 F200 E-{retraction_dual_amount}
    T0 ;Switch to the first extruder
    G1 F{travel_speed}
    ;Put printing message on LCD screen
    M117 Printing...
    end2.gcode = ;End GCode
    M104 T0 S0 ;extruder heater off
    M104 T1 S0 ;extruder heater off
    M84 ;steppers off
    ;{profile_string}
    start3.gcode = ;Sliced at: {day} {date} {time}
    G21 ;metric values
    T2 ;Switch to the 2nd extruder
    G1 F{travel_speed}
    M117 Printing...
    end3.gcode = ;End GCode
    M104 T2 S0 ;extruder heater off
    M84 ;steppers off
    ;{profile_string}
    start4.gcode = ;Sliced at: {day} {date} {time}
    ;M109 T2 S{print_temperature2} ;Uncomment to add your own temperature line
    G21 ;metric values
    T3 ;Switch to the 4th extruder
    T2 ;Switch to the 3th extruder
    G1 F{travel_speed}
    M117 Printing...
    end4.gcode = ;End GCode
    M104 T3 S0 ;extruder heater off
    M84 ;steppers off
    ;{profile_string}
    support_start.gcode =
    support_end.gcode =
    cool_start.gcode =
    cool_end.gcode =
    replace.csv =
    preswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added before the T(n)
    postswitchextruder.gcode = ;Switch between the current extruder and the next extruder, when printing with multiple extruders.
    ;This code is added after the T(n)
        • 9 replies
