'Print one at a time mode disabled. Object too tall.'
Posted
(edited)
· 'Print one at a time mode disabled. Object too tall.'
The object is too tall for "one-at-a-time" cause if you place multiple of these on the bed, and the printer moves to the next one the already build can get knocked over by the x/y/ axis.
So you can print multiples, but only all at the same time. To print one-at-a-time the objects need to be smaller than the 'gantry height' which is the distance from the tip of the nozzle to the lowest of x/y axis (= 48 mm)
If a object is to big to print it will turn grey in cura.
In general if you want to see how cura behaves have a look at the layer view, this will explain the difference between al-at-once & one-at-a-time the best... just try both by loading a few small objects in cura.
S-Line Firmware 8.3.0 was released Nov. 20th on the "Latest" firmware branch.
This update is for...
All UltiMaker S series
New features
Temperature status. During print preparation, the temperatures of the print cores and build plate will be shown on the display. This gives a better indication of the progress and remaining wait time. Save log files in paused state. It is now possible to save the printer's log files to USB if the currently active print job is paused. Previously, the Dump logs to USB option was only enabled if the printer was in idle state. Confirm print removal via Digital Factory. If the printer is connected to the Digital Factory, it is now possible to confirm the removal of a previous print job via the Digital Factory interface. This is useful in situations where the build plate is clear, but the operator forgot to select Confirm removal on the printer’s display. Visit this page for more information about this feature.
ultiarjan 1,223
Edited by GuestLink to post
