@ieol2015...... you must be using the wrong type of glue stick or something as i disagree with all of your comments when it comes to glue sticks???
With PLA I use a certain brand of glue stick and it lasts many multiple prints, I.e. around 10 to 20 before it needs to be added or re-applied, and I NEVER re-align my print base and always get perfect bottoms on the prints.
Just because you take the glass plate off, doesn't mean you need to realign everything! thats madness. I take of the plate everytime but never re-align!
I've only used that Klapton tape once, but feel that the only people who are using it are simply using it as they have not mastered printing with glue stick. or lack a heated bed and are forced into using it for something, as it most definitely not quicker to apply and re-apply than glue, and wont give any better results than well applied glue either and the bottom is as flat as the glass plate with NO BUMPS! and the glue stick is cheap as dirt and lasts almost all year.
There are bumpy glue sticks and there are smooth glue sticks. Obviously use the smooth one. Problem solved. No need for tape ever, unless you are going down the ABS route that is, but i don't so with PLA you just dont need it.
?? Are you kidding right?
Ok... first:
1) If you have used Kapton once how can you have the knowledge to comment??
2) Fact no words! show me something, photos videos... or you are just writing to spend your time and mine (as you have replied to me....)...
3) I never wrote glue stick gave you BUMPS on the print I write it's UGLY (there is difference, isn't it??)
4) The glass bed plate isn't on a rock mounting support and when you take it off to clean it you HAVE to realign no excuse... or your alignment is 1 or 2 mm (millimeters), so in this case you don't have to realign it .... (mine is about 20 micron so if you take it off you HAVE to realign it...)
5) the glue stick I use is the one that comes with the Ultimaker 2
6) I doubt you can do more than 2 print on the same base of glue stick because it means that the PLA doesn't stick to the glue you put on glass plate to make PLA sticking to it!!!!
So please show me a video where you print something , remove it and print again on the same place and again and again as you write.
and last but not least :)I wrote that glue stick is good as Kapton (but for me , with some disadvantage for the glue stick) so please, read it again because your statement about my comment made me thinking that you are a resellers of glue stick
Hyrumaze 1
Each one has his school.
Using the Kapton for the pla is pretty pointless, but for the abs or any other material with heavy warping it's cost and time saving in the end.
Most of the time, i do very large printing or a lot of smalls pieces. When i came back and see a 55 hours print failed because the glue wasn't strong enought or having only 5/8 pieces okay, it can be pretty anoying.
