I think generally, you can tell by looking at it before you mess around with it if it's at the middle or top. The machines come pre-tuned so you probably don't have to mess with it unless you start having issues that point directly to tension.
You can tell if the tension is too high or low by looking at the pattern that is imprinted onto the filament itself after traveling through the knurled bolt. The filament should have little pyramids pressed into it, usually about 3 pyramids wide with equal space between the pyramid imprints. and the filament should be round.
While the documentation may make it seem like an important thing to look at, practically speaking it's almost never the cause of printing issues because it's set by the factory, and it doesn't really change much over time.
valcrow 144
