Extruder Jam Issue
rift
Posted · Extruder Jam Issue
PLA clogs happening at the PEEK end.
Has anyone been able to find a good work around to this? Its started to become more frequent on my machine, and I have already trimmed the PFA tube twice because the end was too mangled to be reused. I'm at the point now where I will soon have to replace the PFA tube because its going to be too short.
The weak point is clearly the push-to-connect fitting. Its just not able to handle the pressure that's building up while printing at high speeds.
    Joergen do you have a none stock PEEK Baffle? The one in my machine just barely sticks up on the inside of the PEEK enough to be flush against a straight cut PFA tube. I could do the chamfering you show in your post however it would not sink around the PEEK baffle as much as it does in your pictures.
    Mine is non-stock by now (had to replace the brass tube, but the PEEK is still the original, I left the PEEK away for illustration purposes in the link above), but I think even a tiny bit of chamfering with the original tube will help with the seal... The important thing is that the PLA never ever gets in contact with the PEEK.
        • 9 replies
