Posted
(edited)
· ended Community Contest, part 2 | The Ape.
made one layer of spikes: copied 44 ones radial, copied this layer above with a distance of 0.2 mm (layer thickness) and rotated slightly. copied these two layers over the whole body with the layer height distance. Made an offset from the body, about 3mm wider en split the spikes with this. Most work was removing the acces spike stuff, but this way the outline follows the body.
peggyb 170
Edited by GuestLink to post
