tasopoulos 40
I tried Acetone smoothing, and while it helps with the shining of the model (and very slightly with the smoothing of the bottom), it's still far from perfect. I've also thought about splitting the part in 2, but I'm afraid the seam will look bad in the end. But it definitely doesn't hurt to try.
Labern 772
There is no way that you can print it as smooth as the top.
One option is to cut the model in half at the most flat spot then rotate so each end is on top. Then glue each half together.
But if you want it all one piece then It's just a matter of filing it, then smoothing it with chloroform, ethyl Acetate, acetone dip or you can quickly go over it with a blow torch.
Edited by GuestLink to post
