Leuk gedaan Arjan! Ik loop ook continu te klooien met die nozzles, dit zou iets voor mij zijn!
I'm glad you posted this. I need to create a threaded part, a mount that threads into a aluminum housing.
- 7 months later...
Thanks for the tip! Are you printing with supports? The slope of the thread profile is 30 degrees, so I would expect that you would need to. I'm trying to design a part with threads right now.
Thanks!
ultiarjan 1,215
Hmm not sure I was clear enough
only the insert is printed. The box is a small marketing giveaway from a producer of plastic products...
I can share the insert and thread if you want.
