tinkergnome 918
Maybe you should reload it (UMO+, not UMO in Cura!).
Yep, if this is a "fresh assembled" printer - upload the correct firmware with Cura and don't forget a subsequent "Control" -> "Restore failsafe" and "Control" -> "Store memory" (on the UltiController).
This will set the correct values for steps/mm (amongst other things).
1
Dim3nsioneer 556
To me it looks as if the bed executes a controlled drive. I think something with the z steps per mm setting is wrong. Did you load the correct firmware? Maybe you should reload it (UMO+, not UMO in Cura!).
