Thanks for the reply. In response:
The Teflon coupler was replaced along with nozzle when I installed the new kit. Even then, the previous Teflon coupler had probably been used for <100 hours.
I made sure the temp sensor was tight enough when I installed it, but I will check this again if/when I disassemble it again.
Since replacing the nozzle I have not printed ABS above 250C.
Here are some recent photos. The first is the test piece I printed after changing over to PLA in the new nozzle. This is after using ABS and performing two Atomic pulls in ABS, two Atomic pulls in PLA and bit of wire wriggling to clear the nozzle. As you can see it completed it but the surface finish is not great:
Here is the next piece in PLA with epic under extrusion for no obvious reason:
Here is the exact same part printed in ABS (this is after two Atomic pulls in PLA before inserting the ABS):
gr5 1,967
There are sooo many causes of underextrusion. Here are 2 of them - the white teflon part degrades pretty quickly at temps above 240C so it may be time to change out that part. People who switch from ABS to PLA in particular have this problem plus bits of ABS dust showing up in the nozzle.
Another thing is that you replaced the temp sensor. If the sensor is loose it tends to read low and so the nozzle is hotter than normal (as much as 20C). If the sensor is tight the nozzle can be as much as 10C cooler than normal. While it's underextruding I would go into the tune menu and go as high as 240C (not just 220C) but don't go over 240C for PLA.
Another thought is that if I print ABS at 260C I get clogs incredibly easy - especially if I print too slow or let it sit like that without printing for a minute. ABS just tends to bake into a gummy gunk very quickly and easily.
I'd like to see some closeup photos of underextruded parts please.
