problems in layer view
cowardc
Posted · problems in layer view
sorry for the poor quality but you can kinda see the problem that im having im sure its a simple explaination but where are the top few layers of my model not showing the layers clearly its coming out very thin
thank you
charlie coward
    to help you solve the problem of wall thickness of your model, you can use MeshMixer (free).
    Import your still and under --> Analysis --> Thickness you can generate a desired wall thickness.
    Also you can upload your model to Shapeways.com and choose a material with a specific minimum wall thickness and let the online repair generate an update.
          • Confused
        • 9 replies
