There are different gcode flavors. On default, Cura generates Ultigcode for the UM2. Temperature is then taken from the material profile stored in the printer itself. If you want to control temperature from Cura, you still have to use legacy Cura I think as you would have to change the gcode flavor to 'RepRap' which the new Cura does not support yet (but I'm not 100% sure).
Dim3nsioneer, thanks for your response!
How should one know which settings defined in Cura are and which are not taken over by UM2 and is this documented somewhere?
When Cura is set to generate Ultigcode for UM2 would it then not make sense to have settings that are to be defined on UM2 itself greyed out in Cura?
Dim3nsioneer 556
