Cura gcode start
atooltoscream
Posted · Cura gcode start
I have a 3d printer at home (M3D) and we just got an Airwolf HD2x where I work.
I use Cura for slicing and gcode creation in both cases, 15.04 for my printer and 15.04.3 for our work printer. My question is, why do my parts perform a gradual approach when a print starts? What I mean is, the print head will start along the path of the first bead but it will take anywhere from a few mm of travel to a few inches of travel before the print head is close enough to the surface to start laying down filament. So basically, my prints have a line of missing material.
Is there a setting in Cura that makes it behave this way?
Thank you so much
    Posted (edited) · Cura gcode start
    @atooltoscream
    Sorry, but can you share some more informations?
    - Which printer profile do you use within Cura?
    - How does your start gcode looks like?
    A short google search found this example profile for the Micro 3D
    ...and the Airwolf FAQ mentions a "recommended profile" for Cura "provided on the USB drive received with your printer"...
    Have you tried this already?
    Anyway... it's just my personal thought, but i assume the Cura developers can only make a guess about your printer(s). Perhaps the linked sites are a better place to ask...?
    @atooltoscream
    Thanks for the response. For my M3D I'm using the example profile that you linked. For the Airwolf, I set Cura up per their instructions in the user manual. I loaded the ABS profile from the Airwolf USB drive and the only things I changed were certain parameters (fill, shells, etc.). I didn't change anything about the Start/End G-code.
    My workaround so far has been to print everything with a raft or brim so the printer is laying down filament by the time it gets to the actual part. I'll paste the G-code start below:
    M190 S115.000000
    M109 S240.000000
    ;Sliced at: Mon 07-12-2015 16:49:52
    ;Basic settings: Layer height: 0.3 Walls: 1 Fill: 0
    ;Print time: 6 hours 49 minutes
    ;Filament used: 15.87m 125.0g
    ;Filament cost: None
    ;M190 S115 ;Uncomment to add your own bed temperature line
    ;M109 S240 ;Uncomment to add your own temperature line
    G28
    G90 ;absolute positioning
    G21 ;metric values
    M107 ;start with the fan off
    G1 Z15.0 F9000 ;move the platform down 15mm
    G1 F200 E3 ;extrude 3mm of feed stock
    G1 F9000
    M42 P6 S255
    ;Put printing message on LCD screen
    M117 HD Printing...
