or, is all the abs well removed before you started with pla,
if there is some left and doesn't melt at pla temp. it will block the flow...
Thanks for these tips.
I guess I have to check the nozzle.
I'll let you know what was the reason for incorrect printing with PLA.
Br. Aarne
Daid 301
Odd, the defaults have been made to print with PLA, so the setting you have should be fine. Are you sure you are not swapping the ABS and PLA and where printing with PLA just fine?
