Starting print problems
SG91
Posted · Starting print problems
Hi
When I start A print it comes no filament from the nozzle until like 30seconds in.
That screws the bottom layer all the time.
But after a while it seems to work OK ..
Cos I already printed A robot and now a wrench.
But its not top quality.
Out of ideas ,
    Posted (edited) · Starting print problems
    but its weird everybody else on youtube seems gets it almost perfekt when it begins Printing.
    Think its something wrong with my machine then..´ It was a build kit . I can mention one thing the  heat sensor for the head was to short (wire). maybe they sent the wrong Cable?
    I Think it was made for the ultimaker 2 cos for me the Cable end only reached the middle back of my original.. Had to take it out from the tube and install it by a short cut in the front down the right bottom front hole..
    I Think it was made for the ultimaker 2 cos for me the Cable end only reached the middle back of my original..  Had to take it out from the tube and install it by a short cut in the front down the right bottom front hole.. maybe messes with the temps ?
          • Confused
        • 4 replies
