A wooden box for umo?
Posted (edited) · A wooden box for umo?
I got the idea to build a sound isolated ish wooden box with a glass door. (should have a small gap between).
Then put my ultimaker original in it. Also to get more stable temps when printing Abs.
Is this a good idea or can the spool filament get over heated in there ? will it damage the electronics?
    Posted · A wooden box for umo?
    It would be better for the longevity of the electronics if you fabricated a door system and hood onto the frame itself and pulled the X and Y axis steppers out into a direct drive setup. You could leave them inside the enclosure if you wanted, but I would recommend getting some cooling fans then. You won't have to worry about the spool as the glass transition is much higher than the printing environment would be.
    Okay! but still gonna try my idea out first.
    Started to build A sliding platform on the bottom today.
    would be more accessible to work with the umo between prints.
    And a cooling fan for the Electronics board.
    its starting to look like a box. had to be tall cos of the feeding tube.
    Think Im gonna paint it white, add legs and so on.
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 14 replies
