thanks for the suggestion,
However I Like Wood ! ... not so easy to find ... easier to find petrol derivates ...
Bonjour Steve,
Rechercher dans : contreplaqué Aviation.
A+,
Willy.
Hey Steeve
Try the PA Busines. The Rack Cases use 4-9mm plywood in different colours.
Here you can ask for some: pa@thomann.de
And here you'll find the Cases:
http://www.thomann.de/fr/cases_racks_housses.html
Thanks all I've finally found 6mm
if the 5mm instead of the 4mm is an issue I'll use pmma.
snowygrouch 1
Why do you want to make it from plywood ?
Have it all cut from Polycarbonate, might need to have it waterjet cut instead of laser.
C.
