lexJena 0 Posted January 16, 2016 in Temp Sensor Error on Ultimaker 2 Extended+ Hi, i have the new Ultimaker and I want to look on the connection but I can't remove the two screws. I hope this two screws are right? Share this post Link to post Share on other sites
Labern 715 Posted January 17, 2016 in Temp Sensor Error on Ultimaker 2 Extended+ Yes they are the screws to remove the main board cover. Share this post Link to post Share on other sites
valcrow 144 Posted January 17, 2016 in Temp Sensor Error on Ultimaker 2 Extended+ When does the error occur? When you start a print as it's heating up? To remove those screws, lift the bed up and use the screw driver/allen key on the top side, and hold the nuts in place on the bottom side (as in your picture) Share this post Link to post Share on other sites
lexJena 0 Posted February 2, 2016 in Temp Sensor Error on Ultimaker 2 Extended+ Thanks, but i think there is a problem with the firmware. Sometimes before I start the print, I go directly to tune the nozzle temperature and the temperature standing on 0 degrees. After I change the temperature there is no problem. Share this post Link to post Share on other sites
