Yes, a kit will be made available. We don't have a hard date for it yet AFAIK but it'll be later in Q1 last I heard.
Okay is there any chance I can just buy the kit or just the feeder right now, because as you can understand it is hard to get things here to Kenya and I am in America right now. And I have been having the problem again where it is just chewing through my filament
Dim3nsioneer 559
@Jear_bear524, I think you have two possibilities: Either you contact FBRC8, the US assembler of Ultimaker in Memphis, and explain them your situation (and maybe find an arrangement) or you print the Robert feeder which needs only parts from the original feeder except one additional M3 screw (which you might be able to get in Kenya?)
I am also in NY so if you have any contacts there that I can meet up with and try to sort this out with it would be very much appreciated
Yeah its just the problem is that my printer isn't printing right now because the feeder is just chewing through the filament I can't get a finished print. :(
Print slower and disable retracts. Also, maybe it's just the spring too tight?
Dim3nsioneer 559
An US 3DHub might be able to print the parts for you while you're in the States.
Im printing at 50ms and why would no retraction help because then there is going to be a lot of stringing won't there?
There are many reasons that can do that. Maintly feeder way too tight, bad filament or too hot environment so the heat from the motor goes to the pla and become softer. Without retractions you get strings, unless you print too cold + slow + fast travel moves. Anyway if you can print a bad looking but ok feeder, that will allow you to change it and print a good quality one (if the feeder it's the cause).
- 2 weeks later...
Hi guys,
AFAIK UM2+ uses a geared feeder, with a 1 mod and 11 teeth and a 1 mod 44 teeth gear, which multiplies 4 times to the torque. Also, a smaller driving gear and a lever with longer arm. The lever can be pulled by hand. All these added more driving force to the filament and also increase precision.
I've experienced under-extrusion a lot for quite some time! So I'm keeping track with improvements and modifications with this respect a lot. I was impressed and inspired by the belt gearbox feeder by Meduza in this thread:
https://ultimaker.com/en/community/17033-meduzas-bolt-on-belt-geared-feeder-upgrade-for-um2
as well as the original UM2, UM2+ feeder design.
With this knowledge I'm experimenting with my re-implemented UM2+ feeder, with printed parts, gears and 5mm rod and other parts from the original UM2. I'm using the original mounting holes of UM2 so no modification to the UM2 back panel is needed. And software side the only thing I've done is recalibrate and re-entered the E-step by using G-Code command
M92 Exxx
I just finished the prototype yesterday (with three 5mm flanged bearings, two brass gears, 0.5 mod 18 teeth and 0.5 mod 72 teeth resp. and 5x40mm steel rod) It works fine! The only thing I was not satisfied was the noise produced by the brass gears. It was a bit louder than the original UM2. Mostly was the clicking sound when retracting. I'm planning to use POM gears instead. But for now I'm also experimenting with printed gears, (1mod 10teeth and 1mod 35teeth).
Since most of my parts were printed in PLA or PETG, I'm not sure how long it will last. Especially for the lever. If anybody interested in it, here's my current version
http://a360.co/1PvoHyX in Fusion 360 (WIP).
Edited by Guest-
1
Nicolinux 288
As far as I know you can upgrade an UM2 to an UM2+. But the +kit is not out yet. Maybe contact @gr5, he might have some infos and he is from the USA.
