cloakfiend 995
The main thing that all people need to consider is that post work is essential even if its only a bit. nothing comes out perfect from any printer from what ive seen. Things need to be finished, polished, glossed whatever.
People with less post-work experience will simply not produce the same quality of print finish as those with more. Its that simple. You need to want it to look good and know what to do to get it the way you want. Sometimes it take time, sometimes not. Just practice and i would definitely recommend needle files for seam lines if you are gluing things. After acetoneing glued objects, the acetone melts them together so when you sand the seam down, often you dont even need any filler as the melt has fused the seam together!
I personally like to get things as good as i can before i paint them, but everyone has their methods and don't expect everyone to do things the same way.
Superglue is NOT affected by acetone BTW. And this is a very useful fact.
Edited by Guest- 1
gareee 39
Since I'm painting 99% of what I'm printing, the print lines don't bother me at all. I just did the gcreate rocket, and it was first sprayed with the rustoleum to reduce the line details, and then oversprayed with copper. Detail colors will then be added, and I might then add weathering as well. As a long time scale modeler, I expect to do paint ops on almost everything.
