Btw an Image of some filament I took out of the spool and did 8-10 knots, and then twist it. Also did the same with other part, leave it for 2 weeks on the ground and still wasn't able to snap it. It's quite flexible, but with enough infill it's also quite hard (pla it's harder, but snaps faster also). This never snaps (printed part ofc can do, but only on the weak between-layers angle of the prints).
- 3 months later...
PLA Tec looks like an awesome material! Anyone made more tests with that?
Surface looks better than PLA? It's a good option for people that don't like ABS?
Cheers!
Edited by GuestFor me it has become the number 1 filament. I'm using PLA if I want color or if I want to save the higher cost. I think PlaTec is easier to print, it has better surface, I was able to printed a small overhang with 80°, edges don't curl up. And temperature resistance is much better too. Only downside: I need hairspray (3dLac) for adhesion, although I'm not sure, if my bed was leveled good. Didnt try it without again. If you want a bit of color or black, GreenTec seems to be the same stuff at same price but in a few colors at least.
- 1
I just use a bit of diluted glue stick works fine for me...
I added a thin PEI Ultem sheet to one of my spare glass beds and PlaTEC / GreenTec sticks extremely well to it. Sometimes maybe even a tad too well. I prefer this over the hairspray or glue approach, less messy. Since I am using pretty much nothing but PLA and GreenTec I am all set at the moment.
@avogra this might be interesting for you
https://ultimaker.com/en/community/33206-greentec-pla-easy-removal-after-hairspray
- 1
Thanks, I will try that
- 7 months later...
I'm making some tests with this filament since january/17 and I love it! It provides a beautiful touch/finish (less post-production), excellent heat tolerance and prints overhangs with angles up to 70 degrees with 0.1mm layer high, in my tests. It can be boiled to get better mechanical resistance. Just warping a bit some small parts but good bed adhesion with glue and spray. I used 3/4 of the 750g spoon.
I will ordering as soon as possible more PLA Tec to my business and I got some good news from the manufacturer that the inner diameter of the spoon hole has been raised to the standard size (50mm), actually a little larger than Ultimaker and ColorFabb, and now they are making new colors available for PLA Tec
- JET (like a deep black);
- SUN (yellow),
and soon:
- OCEAN (blue),
- SNOW (white);
- FRESH (green);
- XOCO (brown);
Red and Black for PowR, the brand new filament from twoBEars:
I actually would like to know the diference beetwin Linen and PLATec, I got in doubt if I get Linen to. For PowR I will order one roll to make some tests and I will post a topic for this...
@avogra and @foehnsturm tested these PowR or Linen?
Never heard of PowR I have used Linen and Silk, and I think they are quite different compared to PlaTec. They both give a very special surface finish but they don't have the mechanical and thermal properties of PlaTec. Linen has quite uneven surface so you don't see the layers anymore. Silk has a very special shimmery gloss, it actually reminds of real silk. They handle overhangs very good too. But I had inconsistent flow with linen a few times. And I wasn't able to reproduce the same silky gloss after the first test. Probably my fault. Anyway after initial enthusiasm, PlaTec is the one filament I still use regularly, while the others are those exotics, you take into your hand every other month and think by yourself "ahh, ah have to use that for something" and then put it back ;-)
I have now printed a couple of items in BioFila PlaTec. The result is very nice and it is super easy to print.
I have some concerns though with layer bonding. Like @ultiarjan mentioned it delaminates easily, in particular when you follow the recommendations (0.1 layers @ 195°C).
I get better results printing a bit hotter and avoiding fan when not necessary.
Anybody else facing delamination? (Only thing I found is this thread on the Prusa forum which is not conclusive...)
- 1
What you mean with inconsistent flow? I note some gaps on layers twice... like some underextrusion dots that made my thin parts weak. But it was in the middle of the object even with low speed of 25-30mm/s at 0.07mm. I was thinking that it maybe occurs becase of the alternative spoon holder (I'm using this one designed to Taulman spoon) without bearings, considering that the inner hole has a recicled paper and it may cause more friction. I cannot live without irobert low friction spoon holder... the wider hole of the new spoon is a big improvement to me.
hahahaha... thanks for the tip!
Delamination after boiling? I never noticed delamination here, but I never boiled too. Edit: I'm actually using this filament to print bones for cirurgical planning, the milky colour looks perfect for it, with no pos-production or machanical properties needed for now. But I will try to make some parts for drones, specially with this PowR one.
By the way my settings to 0.1mm for PLATec with S3D are:
first layer 204°C, 200% high and 140% width, no fan
other layers 199°C, full fan
sometimes I use 0% fan for the first layer... 40%fan, 60%, 80% and 100% at 20th layer
Edited by GuestI found a PowR video on youtube. It's probably not the best method to prove resistance but note the subtitle: "Our brand new material bioFila PowR, with a softening temperature of about 140°C".
It means that the extruder temperature is 140? Or it's heat resistent until 140 degrees?
Looks like a little soft like some flexible filaments... just supposing because of the end of the video... I hope it's easy to print
No, not after boiling... if you apply stress on the parts they will easily break on the layers; the layer bonding is not that great.
I have no layer bonding issues with green-tec.
do print a bit hotter. like 210/215 with 0.15 layers and 40 mm/s
I have also used the same temps as @ultiarjan and I have not had any layer bonding issues.
The only thing I have noticed with greentec is that the filament diameter on the spools I got is not so consistent and on at least one spool it exceeded the tolerance they stated. It is not as consistent as the ColorFabb filaments I have.
But it still prints great
- 1
Yes, that's my experience as well, just weird that the manufacturer recommends 195°C@0.1mm for strong prints...
foehnsturm 969
I printed two spools of the very first Linen and liked it very much (surface feel, overhang quality ...). A few months later there were two variants like "standard" and "eco" for quite a while which I found confusing but now it looks like they sell the original one again.
I'm currently using Greentec by extrudr at 210°C. Then I discovered weak layerbonding and thought that I should go back to PlaTec. most prominent case was a part with a wall only 2 perimeters thick. in pla i could easily bend it over 90 degrees without damage, greentec snapped off imediately. i will try it a bit hotter, but i think 210 fairly close to your recommendation.
What you mean with inconsistent flow? I note some gaps on layers twice... like some underextrusion dots that made my thin parts weak. But it was in the middle of the object even with low speed of 25-30mm/s at 0.07mm. I was thinking that it maybe occurs becase of the alternative spoon holder (I'm using this one designed to Taulman spoon) without bearings.
Exactly that, I too had same layers, that look underextruded and weaken the print. maybe a bigger nozzle is a good idea for linen.
And how does plaTec behave over a longer time?
Normal PLA gets harder and more brittle: after a year or so, it may snap easily when stressed (like you would do with hooks, keychains, etc.). And it may lose its shine and get duller.
Does this also happen with plaTec?
Well, imo, extrudr publishes very poor info/data on their filaments so i'm taking most if their info with a grain of salt. Which is a pity since at least Greentec is great...but without the info @neotko shared I would not have tried it, yet at least.
At least they are very helpful when you talk to them directly. When they launched their TPU filaments recently I asked for data sheets so I could see what temp resistance they had etc. since there was almost no info available on their site. And I got the data, and more, from them in less than a day. Yet, as of today, there is no data publicly available on their site. And today they released yet another new filament...NX2...with little to no information available :/
neotko 1,417
@claus I posted a small review of the PLA-tec black from Extrudr here it covers the basics, ofc it need's more testing, but looks very nice.
