I would welcome some help on materials. Even though I'm fairly new, I did notice a huge difference between printing with the white PLA that came with my UM verses the orange "JET" brand PLA I'm currently using. The orange blobs up a lot and doesn't print the same dimensional shapes as the white does. The parts just don't fit together with the orange as they do with the white without a lot more clean-up and modification.
There is a big difference between print settings and filament quality.
In regards to the print settings, there arent many differences between PLA and ABS. ABS just needs a bit more material to extrude (flow adjustment of 1.02-1.06), and prints obviously warmer. The slight differences between the UM temp measurements are pretty much the monkey wrench, that will prevent your proposed database from becoming useful, other than stating that 210C is great for PLA, and 230-250 is great for ABS. There are way too many variations between manufacturers and colors to really pinpoint a single setting for each spool out there on the market. In that regard, i find your DB proposal absolutely futile.
On the other hand, the reprap wiki has 2 pages about filament suppliers and their filament quality, which is a great resource, and can be updated by everyone, including the huge 3D community outside the ultimaker world:
- 3 years later...
I bought several Auroram PLA 2.85 spools and would like to know if I have to make any changes on the temp setup on my UM2+ ?
Im (still) pretty new to the 3dprinting World, but in my experience, i see a lot of finetuning of the settings even when printing in the same filament. (colour, vendor, ect.).
I see a lot of changes in how the printquality is just because the objects printet has different complexity.
So in my opinion i feel that every printer with every filament has to be tuned to the specific print-object to get the desired output.
Its not only the temperature, speed or flow rate. Its altso about how you cooling Works or small settings in your slicer-programme. - So from my experience, its only you who knows excatly how your printer Works. Start with the recommended temperature and finetune from there.
That is really what I thougtht , i'll start a "trial and error"print to get there, but aprecise setting would be time saving. Thanks anyway
Do you have a specific item you want to print? if you have, upload a Photo, and there is a lot of Guys inhere that could tell you a thing or two..
I browse in "tips&Tricks" from time to time, just to read about printing and printer behaviour, and for me, some of the Things are very usefull and others dont Work on my machine.
I have been printing almost non stop for over a week now, and im beginning to see a slight pattern in the settings, but its not the same as some others in here. So go ahead and print a object, finetune to that specific object, and do it all over Again for the Next one.
I know its not a direct answer to your topic, but i dont see a strict pattern in the settings yet.
@jamado: if you want to print with very fine details, smooth surfaces, and hard-to-see layer lines, I would suggest that you read the thread by Cloakfind on smoothing PLA with aceton. This thread contains a wealth of good info on temperatures, speed, layer heights, etc. for finest quality. Plus it has a lot of photographs showing each test. It is a lot of reading, but worth it.
I think it is this URL:
https://ultimaker.com/en/community/10412-acetone-finishing-on-pla
Daid 301
We test almost all our PLA. Only our white needs a slightly higher temperature, the we print at 210C. We notice more slight variations between machines then between PLA.
