Cura Won't Load
breichert
Posted · Cura Won't Load
Until recently we were running Cura 14.06. A few days ago the splash screen starting coming up but it stopped going past that. We reinstalled with no luck. We installed 15.04.4 and get the same result. We've tried other users on the same PC with the same result.
We are running Windows 7 SP2 x64.
Any ideas what might be going on or where to look for clues?
Thanks,
Brad
    Posted (edited) · Cura Won't Load
    Have you recently done any changes to firewalls/anti-virus software on the PC? cura uses a local TCP socket to communicate between the front and backend so if that is being blocked that might have something to do with it perhaps?
    Nope. I can only recommend trying the new version of Cura. It will be in beta soon.
