WTS Ultimaker Nozzle, Mounted Once...
Hahah! yes, "like new, already assembled"
1
I've had my UMO going since August 2013 and only replaced the nozzle last fall (jammed it up good). I had bought the dual extruder upgrade so I had spare parts available!
I'm curious about picture where you printer looks encased in something...?
I work at a polyethylene foam factory, and have access to a HUGE XY plotter table, so designed and cut out of foam a sound insulation / sort of heat retention box.
cut from 28mm thick foam, then with 25mm foam black highligts (just swap out the white and black pieces for prettyness)
That's excellent! My UMO is very noisy too!
Edited by GuestThat foam box looks neat. Your company should sell it on ebay. I bet it would even be nice for a um2.
Ronan 58
