I had this problem with a 0.25mm nozzle until i realised that not just changing the nozzle size on cura was essential , but using a higher flow rate to build pressure. this takes some tinkering.
Anyone else found this or just me?
Just you
using the 0.25mm nozzle takes time to get used to. You need to increase speed or drop temp a bit.
But it seems amont has a issue of being supplied the wrong sized nozzles.
There is one dot on the nozzle.
Since my original post I have found another thread https://ultimaker.com/en/community/8689-custom-heater-block-to-fit-e3d-nozzle-on-ultimaker-2-the-olsson-block page 30 which refers to considerable confusion regarding the nozzle markings and the fact that some wrong sizes were sent out.
I must be the recipient of some of that batch.
1 dot should be 0.40mm where and when did you buy it?
I bought the nozzles in June from direct from 3dSolex.
I have bought more nozzles from the UK agent which arrived yesterday, and the same micro drill will pass through them. They do of course have 0.4 marked on them.
Dim3nsioneer 556
How many dots are on the nozzle?
