Ultimaker 2 ABS printing +Zebra Plate
EvilNivel
Posted · Ultimaker 2 ABS printing +Zebra Plate
Hello Friends.
I am posting some tip how to print ABS without any hair spray ,glue sticks, kapton etc...
just order zebraplate for your printer ~60$
http://www.printinz.com/zebra-plates/
Printing settings change: (other settings are factory default)
Build plate temp: 255
Fan on: 17%
More tips:
ZebraPlate: print on the black side.
Brim: print with Brim to calibrate z axis manually with screws.
Remove the 3d model when build plate is cool with scraper.
  • 1 month later...
Out of curiosity, did you mean that the nozzle temperature was 255, not build plate? The print bed at 255 is, for one, impossible as far as I know, and would also destroy the Zebra plate.
What bed temperature setting are you using? I know some heat is lost between the bed and the print surface (about 30 degrees by PrintInZ's own admission, 110 in the setting vs 80 on the actual surface).
