It looks like you have "Support: Everywhere" enabled... So isn't the green lines you are seeing, auto-generated support?
EDIT: According to Daid (google searched Cura colors), green are supposed to be inner walls... So I dunno.
Edited by GuestIt looks like you have "Support: Everywhere" enabled... So isn't the green lines you are seeing, auto-generated support?
Edited by GuestOk I'll try to remove all the inner walls, now the two grey masses in the right part of the models are walls.
Also, thanks for the info about what the green lines are!
I am wondering whether the model(s) comes from somewhere like (Thingiverse) and is not manifold. If you go to the Netfabb site you can either download their Basic software for free or use their cloud service. It will give you model a healthcheck, I think that is the button with the red cross in the basic software. It may be able to fix it too - it has fixed stuff that I have run through it.
Labern 772
When you are putting the buildings together are you removing the joining walls to make it one solid model?
Your Xray looks mainly white which means it has internal walls. it should look dark blue.
what you can try is in the expert settings there is fix horrible with 4 different options. try selecting option B and try different combinations of them all to see if you can fix it. otherwise you will need to make sure your model only has the outer shell with no internal structure.
