Autre slicer
Wyman
Posted · Autre slicer
Hello...
Est ce que certains utilisent Slic3R ou Simplifi3D avec UMO+ et aurait l'amabilité de m'envoyer un profil (pour PLA) qui fonctionne et/ou correspond aux réglages de Cura.
Merci d'avance.
    Posted (edited) · Autre slicer
    Bonjour,
    Je suis intéressé aussi. Je (re)teste Slic3r depuis quelque jours avec ma nouvelle buse de 0.8 sur UMO. Ça reste un peut nébuleux. Tu l'utilises avec Repetier-host? J'ai pu tester Simplify aussi, mais la licence fait mal au cucul quand même.
    Edit : Mon profil un peut en chantier mais qui fonctionne :
    # generated by Slic3r 1.2.9 on Wed Feb  3 15:16:13 2016[filament:Simple Mode]bed_temperature = 0bridge_fan_speed = 100cooling = 1disable_fan_first_layers = 2extrusion_multiplier = 1fan_always_on = 0fan_below_layer_time = 60filament_colour = #FFFFFFfilament_diameter = 2.85first_layer_bed_temperature = 0first_layer_temperature = 210max_fan_speed = 100min_fan_speed = 60min_print_speed = 10slowdown_below_layer_time = 5temperature = 205[presets]filament = Simple Mode.iniprint = test.iniprinter = Simple Mode.ini[print:Simple Mode]avoid_crossing_perimeters = 0bottom_solid_layers = 2bridge_acceleration = 0bridge_flow_ratio = 1bridge_speed = 60brim_width = 0complete_objects = 0default_acceleration = 0dont_support_bridges = 1external_fill_pattern = rectilinearexternal_perimeter_extrusion_width = 0external_perimeter_speed = 50%external_perimeters_first = 0extra_perimeters = 1extruder_clearance_height = 20extruder_clearance_radius = 20extrusion_width = 0fill_angle = 45fill_density = 0%fill_pattern = honeycombfirst_layer_acceleration = 0first_layer_extrusion_width = 200%first_layer_height = 0.35first_layer_speed = 30gap_fill_speed = 20gcode_comments = 0infill_acceleration = 0infill_every_layers = 1infill_extruder = 1infill_extrusion_width = 0infill_first = 0infill_only_where_needed = 0infill_overlap = 15%infill_speed = 60interface_shells = 0layer_height = 0.4max_print_speed = 80max_volumetric_speed = 0min_skirt_length = 0notes = only_retract_when_crossing_perimeters = 1ooze_prevention = 0output_filename_format = [input_filename_base].gcodeoverhangs = 1perimeter_acceleration = 0perimeter_extruder = 1perimeter_extrusion_width = 0perimeter_speed = 30perimeters = 1post_process = raft_layers = 0resolution = 0seam_position = alignedskirt_distance = 6skirt_height = 1skirts = 1small_perimeter_speed = 15solid_infill_below_area = 70solid_infill_every_layers = 0solid_infill_extruder = 1solid_infill_extrusion_width = 0solid_infill_speed = 20spiral_vase = 1standby_temperature_delta = -5support_material = 0support_material_angle = 0support_material_contact_distance = 0.2support_material_enforce_layers = 0support_material_extruder = 1support_material_extrusion_width = 0support_material_interface_extruder = 1support_material_interface_layers = 3support_material_interface_spacing = 0support_material_interface_speed = 100%support_material_pattern = pillarssupport_material_spacing = 2.5support_material_speed = 60support_material_threshold = 0thin_walls = 1threads = 2top_infill_extrusion_width = 0top_solid_infill_speed = 15top_solid_layers = 0travel_speed = 130xy_size_compensation = 0[print:test]avoid_crossing_perimeters = 0bottom_solid_layers = 3bridge_acceleration = 0bridge_flow_ratio = 1bridge_speed = 40brim_width = 0complete_objects = 0default_acceleration = 0dont_support_bridges = 1external_fill_pattern = concentricexternal_perimeter_extrusion_width = 0external_perimeter_speed = 30external_perimeters_first = 0extra_perimeters = 1extruder_clearance_height = 20extruder_clearance_radius = 20extrusion_width = 0fill_angle = 45fill_density = 15%fill_pattern = honeycombfirst_layer_acceleration = 0first_layer_extrusion_width = 200%first_layer_height = 0.4first_layer_speed = 30gap_fill_speed = 20gcode_comments = 0infill_acceleration = 0infill_every_layers = 1infill_extruder = 1infill_extrusion_width = 0infill_first = 0infill_only_where_needed = 0infill_overlap = 15%infill_speed = 40interface_shells = 0layer_height = 0.4max_print_speed = 80max_volumetric_speed = 0min_skirt_length = 0notes = only_retract_when_crossing_perimeters = 1ooze_prevention = 0output_filename_format = [input_filename_base].gcodeoverhangs = 1perimeter_acceleration = 0perimeter_extruder = 1perimeter_extrusion_width = 0perimeter_speed = 30perimeters = 2post_process = raft_layers = 0resolution = 0seam_position = alignedskirt_distance = 6skirt_height = 1skirts = 1small_perimeter_speed = 15solid_infill_below_area = 70solid_infill_every_layers = 0solid_infill_extruder = 1solid_infill_extrusion_width = 0solid_infill_speed = 20spiral_vase = 0standby_temperature_delta = -5support_material = 0support_material_angle = 0support_material_contact_distance = 0.2support_material_enforce_layers = 0support_material_extruder = 1support_material_extrusion_width = 0support_material_interface_extruder = 1support_material_interface_layers = 3support_material_interface_spacing = 0support_material_interface_speed = 100%support_material_pattern = pillarssupport_material_spacing = 2.5support_material_speed = 40support_material_threshold = 0thin_walls = 1threads = 2top_infill_extrusion_width = 0top_solid_infill_speed = 15top_solid_layers = 3travel_speed = 130xy_size_compensation = 0[printer:Simple Mode]bed_shape = 0x0,210x0,210x210,0x210before_layer_gcode = end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors\nextruder_offset = 0x0gcode_flavor = repraplayer_gcode = nozzle_diameter = 0.8octoprint_apikey = octoprint_host = pressure_advance = 0retract_before_travel = 2retract_layer_change = 0retract_length = 1retract_length_toolchange = 10retract_lift = 0retract_restart_extra = 0retract_restart_extra_toolchange = 0retract_speed = 40start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\ntoolchange_gcode = use_firmware_retraction = 1use_relative_e_distances = 0use_volumetric_e = 0vibration_limit = 0wipe = 0z_offset = 0[settings]autocenter = 1mode = expert[simple]avoid_crossing_perimeters = 1bed_shape = 0x0,200x0,200x200,0x200bed_temperature = 0before_layer_gcode = bottom_solid_layers = 2bridge_acceleration = 0bridge_fan_speed = 100bridge_flow_ratio = 1bridge_speed = 60brim_width = 0complete_objects = 0cooling = 1default_acceleration = 0disable_fan_first_layers = 3dont_support_bridges = 1duplicate_distance = 6end_gcode = M104 S0 ; turn off temperature\nG28 X0  ; home X axis\nM84     ; disable motors\nexternal_fill_pattern = rectilinearexternal_perimeter_extrusion_width = 0external_perimeter_speed = 50%external_perimeters_first = 0extra_perimeters = 1extruder_clearance_height = 20extruder_clearance_radius = 20extruder_offset = 0x0extrusion_axis = Eextrusion_multiplier = 1extrusion_width = 0fan_always_on = 0fan_below_layer_time = 60filament_colour = #FFFFFFfilament_diameter = 2.85fill_angle = 45fill_density = 0%fill_pattern = honeycombfirst_layer_acceleration = 0first_layer_bed_temperature = 0first_layer_extrusion_width = 200%first_layer_height = 0.8first_layer_speed = 30first_layer_temperature = 210gap_fill_speed = 20gcode_arcs = 0gcode_comments = 0gcode_flavor = reprapinfill_acceleration = 0infill_every_layers = 10infill_extruder = 1infill_extrusion_width = 0infill_first = 0infill_only_where_needed = 0infill_overlap = 15%infill_speed = 60interface_shells = 0layer_gcode = layer_height = 0.4max_fan_speed = 100max_print_speed = 80max_volumetric_speed = 0min_fan_speed = 35min_print_speed = 10min_skirt_length = 0notes = nozzle_diameter = 0.8octoprint_apikey = octoprint_host = only_retract_when_crossing_perimeters = 1ooze_prevention = 0output_filename_format = [input_filename_base].gcodeoverhangs = 1perimeter_acceleration = 0perimeter_extruder = 1perimeter_extrusion_width = 0perimeter_speed = 30perimeters = 2post_process = pressure_advance = 0raft_layers = 0resolution = 0retract_before_travel = 2retract_layer_change = 0retract_length = 1retract_length_toolchange = 10retract_lift = 0retract_restart_extra = 0retract_restart_extra_toolchange = 0retract_speed = 40seam_position = alignedskirt_distance = 6skirt_height = 1skirts = 1slowdown_below_layer_time = 5small_perimeter_speed = 15solid_infill_below_area = 70solid_infill_every_layers = 0solid_infill_extruder = 1solid_infill_extrusion_width = 0solid_infill_speed = 20spiral_vase = 0standby_temperature_delta = -5start_gcode = G28 ; home all axes\nG1 Z5 F5000 ; lift nozzle\nsupport_material = 0support_material_angle = 0support_material_contact_distance = 0.2support_material_enforce_layers = 0support_material_extruder = 1support_material_extrusion_width = 0support_material_interface_extruder = 1support_material_interface_layers = 3support_material_interface_spacing = 0support_material_interface_speed = 100%support_material_pattern = pillarssupport_material_spacing = 2.5support_material_speed = 60support_material_threshold = 0temperature = 205thin_walls = 1threads = 2toolchange_gcode = top_infill_extrusion_width = 0top_solid_infill_speed = 15top_solid_layers = 0travel_speed = 130use_firmware_retraction = 0use_relative_e_distances = 0use_volumetric_e = 0vibration_limit = 0wipe = 0xy_size_compensation = 0z_offset = 0
    merci pour la config... j'ai une UMO+ avec un Raspi/octoprint, pratique car Slic3r permet d'envoyer le gcode directement dessus.
    Voici ma config, basé sur le profil de Cura. Je débute donc il y à des trucs que je ne maitrise pas encore, notamment le rapport taille de la buse et first layer, je pensais qu'il devait être un multiple et inférieur à la taille de la buse, mais sur ta config c'est pas ça... tu peux m'expliquer ?
    Aussi, si tu peux poster ta config pour Simplify3D, je suis preneur. merci
    # generated by Slic3r 1.2.9 on Fri Feb  5 13:48:54 2016[filament:Orange]bed_temperature = 60bridge_fan_speed = 100cooling = 1disable_fan_first_layers = 3extrusion_multiplier = 1fan_always_on = 0fan_below_layer_time = 60filament_colour = #FF8040filament_diameter = 3first_layer_bed_temperature = 60first_layer_temperature = 210max_fan_speed = 100min_fan_speed = 35min_print_speed = 10slowdown_below_layer_time = 15temperature = 200[presets]filament = Orange.iniprint = Normal.iniprinter = UMO.ini[print:Normal]avoid_crossing_perimeters = 0bottom_solid_layers = 6bridge_acceleration = 0bridge_flow_ratio = 1bridge_speed = 60brim_width = 0complete_objects = 1default_acceleration = 0dont_support_bridges = 1external_fill_pattern = rectilinearexternal_perimeter_extrusion_width = 0external_perimeter_speed = 80%external_perimeters_first = 0extra_perimeters = 1extruder_clearance_height = 20extruder_clearance_radius = 20extrusion_width = 0fill_angle = 45fill_density = 20%fill_pattern = rectilinearfirst_layer_acceleration = 0first_layer_extrusion_width = 0first_layer_height = 0.4first_layer_speed = 30%gap_fill_speed = 20gcode_comments = 0infill_acceleration = 0infill_every_layers = 1infill_extruder = 1infill_extrusion_width = 0infill_first = 0infill_only_where_needed = 0infill_overlap = 15%infill_speed = 0interface_shells = 0layer_height = 0.1max_print_speed = 80max_volumetric_speed = 0min_skirt_length = 0notes = only_retract_when_crossing_perimeters = 1ooze_prevention = 0output_filename_format = [input_filename_base].gcodeoverhangs = 1perimeter_acceleration = 0perimeter_extruder = 1perimeter_extrusion_width = 0perimeter_speed = 50perimeters = 3post_process = raft_layers = 0resolution = 0seam_position = nearestskirt_distance = 5skirt_height = 1skirts = 2small_perimeter_speed = 80%solid_infill_below_area = 70solid_infill_every_layers = 0solid_infill_extruder = 1solid_infill_extrusion_width = 0solid_infill_speed = 0spiral_vase = 0standby_temperature_delta = -5support_material = 0support_material_angle = 0support_material_contact_distance = 0.2support_material_enforce_layers = 0support_material_extruder = 1support_material_extrusion_width = 0support_material_interface_extruder = 1support_material_interface_layers = 3support_material_interface_spacing = 0support_material_interface_speed = 100%support_material_pattern = pillarssupport_material_spacing = 2.5support_material_speed = 60support_material_threshold = 0thin_walls = 1threads = 2top_infill_extrusion_width = 0top_solid_infill_speed = 0top_solid_layers = 6travel_speed = 200xy_size_compensation = 0[print:Normal (support)]avoid_crossing_perimeters = 0bottom_solid_layers = 3bridge_acceleration = 0bridge_flow_ratio = 1bridge_speed = 60brim_width = 0complete_objects = 0default_acceleration = 0dont_support_bridges = 1external_fill_pattern = rectilinearexternal_perimeter_extrusion_width = 0external_perimeter_speed = 60%external_perimeters_first = 0extra_perimeters = 1extruder_clearance_height = 20extruder_clearance_radius = 20extrusion_width = 0fill_angle = 45fill_density = 20%fill_pattern = honeycombfirst_layer_acceleration = 0first_layer_extrusion_width = 0first_layer_height = 0.3first_layer_speed = 40%gap_fill_speed = 20gcode_comments = 0infill_acceleration = 0infill_every_layers = 1infill_extruder = 1infill_extrusion_width = 0infill_first = 0infill_only_where_needed = 1infill_overlap = 15%infill_speed = 80interface_shells = 0layer_height = 0.1max_print_speed = 80max_volumetric_speed = 0min_skirt_length = 0notes = only_retract_when_crossing_perimeters = 1ooze_prevention = 0output_filename_format = [input_filename_base].gcodeoverhangs = 1perimeter_acceleration = 0perimeter_extruder = 1perimeter_extrusion_width = 0perimeter_speed = 50perimeters = 2post_process = raft_layers = 0resolution = 0seam_position = alignedskirt_distance = 5skirt_height = 1skirts = 1small_perimeter_speed = 15solid_infill_below_area = 70solid_infill_every_layers = 0solid_infill_extruder = 1solid_infill_extrusion_width = 0solid_infill_speed = 20spiral_vase = 0standby_temperature_delta = -5support_material = 1support_material_angle = 0support_material_contact_distance = 0.2support_material_enforce_layers = 0support_material_extruder = 1support_material_extrusion_width = 0support_material_interface_extruder = 1support_material_interface_layers = 3support_material_interface_spacing = 0support_material_interface_speed = 100%support_material_pattern = rectilinearsupport_material_spacing = 2.5support_material_speed = 60support_material_threshold = 0thin_walls = 1threads = 2top_infill_extrusion_width = 0top_solid_infill_speed = 120%top_solid_layers = 3travel_speed = 200xy_size_compensation = 0[printer:UMO]bed_shape = 0x0,205x0,205x205,0x205before_layer_gcode = end_gcode = M104 S0                     ;extruder heater off\nM140 S0                     ;heated bed heater off (if you have it)\nG91                                    ;relative positioning\nG1 E-1 F300                            ;retract the filament a bit before lifting the nozzle, to release some of the pressure\nG1 Z+0.5 E-5 X-20 Y-20 F9000 ;move Z up a bit and retract filament even more\nG28 X0 Y0                              ;move X/Y to min endstops, so the head is out of the way\nM84                         ;steppers off\nG90                         ;absolute positioningextruder_offset = 0x0gcode_flavor = repraplayer_gcode = nozzle_diameter = 0.46octoprint_apikey = 5CD54CF0E39A49C88E59F1D79D18510Coctoprint_host = 192.168.0.40:80pressure_advance = 0retract_before_travel = 2retract_layer_change = 0retract_length = 4.5retract_length_toolchange = 10retract_lift = 0retract_restart_extra = 0retract_restart_extra_toolchange = 0retract_speed = 40start_gcode = G21        ;metric values\nG90        ;absolute positioning\nM82        ;set extruder to absolute mode\nM107       ;start with the fan off\nG28 X0 Y0  ;move X/Y to min endstops\nG28 Z0     ;move Z to min endstops\nG1 Z20.0 F9000 ;move the platform down 20mm\nG92 E0                  ;zero the extruded length\nG1 F200 E3              ;extrude 3mm of feed stock\nG92 E0                  ;zero the extruded length again\nG1 F9000toolchange_gcode = use_firmware_retraction = 0use_relative_e_distances = 0use_volumetric_e = 0vibration_limit = 0wipe = 0z_offset = 0[settings]autocenter = 1mode = expert
    Effectivement Cura conseil une première couche inférieure à 3/4 de la taille de la buse.
    Dans mon profil "test" j'ai un "first_layer_height = 0.4", avec ma buse de 0.8mm c'est OK. J'imprime en 0.4mm, la première couche est comme les suivantes en fait.
    A vrai dire pour ce réglage je cherche pas trop, je règle plutôt manuellement mon plateau. Je suis aussi débutant sur slic3r, donc ce profil n'est pas à suivre à la lettre bien sûr.
    Sinon est ce que tu as modifié le start g-code? J'ai du mal là dessus. Quand je copie/colle celui de Cura à la place, ça marche une fois sur deux?? :Oje passe par une carte SD par contre.
