Simplify 3D and setting up UM2 EX with dual extrusion
DrewNJIT86
Posted · Simplify 3D and setting up UM2 EX with dual extrusion
So I bought simplify 3D for the hopes of easily setting up a second extruder experiment that I am attempting to perform with my ultimaker 2 extended. Does anyone have any experince with setting up simplify 3d for dual extruder on an Ultimaker 2 Extended?
    Yeah I noticed that its not 100% clear because the second extruder is going to be attached to the existing print head in the empty spot on it. I am also not using a heated head but rather a modified print head to accept silicon. Also sadly theirs almost nothing on it in the simlify3d tutorials, but thanks for helping.
    https://ultimaker.com/en/community/16833-ultimaker-2-firmware-for-dual-extrusion-with-simplify3d#reply-113999
    Read from there and ahead. For something else check simplify3d tutorials
    Well you can configure the second heat on a second process and set it as you want. There's plenty of options there to play with, I don't think it should be hard to configure it.
    Hey neotko take a look at my PM..
    Saw it. I'll answer tomorrow, kinda tired atm. But it's quite easy on s3d (at least on theory)
    Ok no biggy and they said those very words about splitting the atom sending a man to the moon in theory of course. LOL... However thanks for take a look into it..
