tinkergnome 918
Why does it move from front left, to front right, avoiding the left clamp and hitting the right clamp?
It's just the default start-gcode from S3D. After priming at the front left corner: it "wipes" the material from left to right while the buildplate moves up (from z=20 to z=0 if i remember correctly).
These moves bring the nozzle very close to the right clip anyway. Perhaps the position of the y-endstop is slightly different on your second printer - that's why it becomes too close?
I would edit the start-gcode and increase the y positions for the "wipe moves" a bit, or decrease the x-positions (or both...)
If you need to use the full print area you have to modify this method anyway...
SandervG 1,509
Hi George,
It sounds like the size you have set for your buildplate is off a little bit.
What size have you set in S3D? Unfortunately I don't have it myself so I can't give you any directions, but that would be a very obvious reason.
The filament dump it does prior to a print is called priming.
It is building up pressure in your nozzle so it can do a extruder a solid first layer.
Does your print start from the front right corner?
Thanks!
